09-02-2020 11:38 PM - edited 01-05-2022 01:03 PM
Does anyone know if Samsung A71 works on amazing Public Network?
Phones
09-03-2020 08:07 AM
Yes, it will and I have the A70 and it works fine 🙂
09-03-2020 02:14 AM
@Irv wrote:@Austin_YQU It's always good check, just in case.
If you haven't checked this yet, this page from public mobile might help you : https://publicmobile.ca/en/bc/get-started
Just below "activate your card SIM", you will find a field to check phone compatibility. Handy tool.
I hope the other members' replies helped you! Enjoy your new phone 📱🙂
That site is a good tool, but it's not the final answer when it comes to compatibility. The manufactuer often knows best when it comes to the specifications of the device and about the compatibility with certain networks. Band 2 and 5 for 3g/UMTS are important at Public Mobile because without those, phone calls won't work. Band 2 and and Band 4 for LTE are probably the most used, but are not completely required, although it would be a good idea to have them. With any cell phone compatibility check website, there are going to be some models missing from the database.
09-03-2020 02:03 AM - edited 09-03-2020 11:44 AM
09-03-2020 01:56 AM
Probably yes but it really depends on the specific version, such as, SM-A715F/DS, SM-A715F/DSN, SM-A715F/DSM, etc..
09-03-2020 01:01 AM
@Austin_YQU Never say just Samsung A71. Samsung can have many different types of the A71 and there can be types that won't work if the frequencies aren't in it. What's the specific model number?
09-02-2020 11:41 PM - edited 09-03-2020 02:24 AM
@Austin_YQU wrote:Does anyone know if Samsung A71 works on amazing Public Network?
Samsung A71 will work with PM especially the version sold in Canada.
A71 is currently offered by Koodo which is also on Telus network.
https://www.koodomobile.com/phones/samsung-galaxy-a71
