10-13-2023
05:55 PM
10-14-2023
12:14 AM
computergeek541
Hello,
I moved from the physical SIM to eSIM (it happened a few weeks ago)
After the activation, I paid attention to that I could receive but couldn't send SMS messages.
I checked in my device the SMSC number, and saw the number was not available.
Then I tried to update the SMSC manually (SMSC Number: +16475800172) through the *#*#4636#*#*, but unfortunately, I got an error
Does anyone have an idea?
10-13-2023 08:21 PM
@guberm , I assume that you have no problems with phone calls and data? Please try deleting SMS cache and reopening the app. Maybe that will help. Customers should not have to do SMSC editing to make SMS work. If all else fails, reach out to support for assistance.
10-13-2023 06:28 PM
of course
10-13-2023 06:20 PM
Did you type in the number in that area and click update also?
10-13-2023 06:10 PM
Tried already, and unfortunately, the same result
10-13-2023 05:59 PM
On both update and refresh? Maybe try a reset network settings. Or just a full power off restart. Odd that the first screen it's greyed out. I can change mine.
