SMS Promotions
cvulgarelis
I accidentally opted out of SMS promotions.  Can you please add me back on to receive SMS promotions.  I would like to opt in to this service
2 REPLIES 2
HI @cvulgarelis
if you still have the text, try to reply YES to subscribe back (as long as that is not the test saying reply YES to change plan)
HALIMACS
The customer support agents can do this for you @cvulgarelis
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
