Reactivation
Logenisme
I had a number for a while and it has been suspended for a few months and permanently deactivated, is there anyway to get it back?
Or do i need to make new account with new sim??
2 REPLIES 2
HALIMACS
If you were really attached to the number, find out which carrier issued it and activate a short term plan with them first.
If they can pull the number back for you, then you can decide which mobile service provider you want to port to afterwards.
It’s a longshot, but your best option at getting the number is through the original carrier
HI@Logenisme   account suspended for over 90 days will be closed and the number will be back to the pool
if you ported in your number before, your number will be go back to the original carrier, so PM cannot help
But if you got it from PM, Telus or Koodo , maybe agent can help
Message them and ask sincerely
