07-20-2022 09:24 AM
Sorry about jumping on the mms thread I misread it, I'm having problems with SMS I used to be able to send and receive text and pictures now I can only do text, what's happening
Service
07-20-2022 10:41 AM
Yes the special Apple world. 🙂 She needs to turn on MMS in her imessage. She can send instant messages and pictures all day long on wifi or cell data. But that's not SMS/MMS.
07-20-2022 10:35 AM
So I sent it to another Android phone and it worked so it might be my sister inlaw problem as she is a apple user and she has no problem sending to other Apple users
07-20-2022 10:20 AM
Then that's MMS. MMS needs to have mobile data on to send and recieve. Go into your APN settings and check the APN type line. It should have ,mms in it.
07-20-2022 10:20 AM
@Willaug56 that would be MMS
was that a problem only when sending picture to one particular person?
try to send to 2 or 3 different persons and see if they receive the picture
07-20-2022 10:18 AM
I'm getting confused now, I used to send a text with a picture to go along next comment, as a example I would send a picture of our house with a comment right after now the picture doesn't go through
07-20-2022 10:08 AM - edited 07-20-2022 10:10 AM
Yes but then your first post here said you can do texts.
Adding - lol glad I'm not the only one seeing things.
07-20-2022 10:08 AM
@Willaug56 wrote:I apologized for misreading the mms post already I'm talking about SMS
but you said " I used to be able to send and receive text and pictures now I can only do text, "
If you can "do text" , that's SMS. So, is SMS working?
07-20-2022 10:06 AM
Can you screenshot the current APN settings?
and again, your mobile data, voice are both working? SMS is working and just not MMS (Pictures)?
07-20-2022 10:06 AM
07-20-2022 10:02 AM
I'm a little confused of your posts here and the other one.
Can you send SMS? Can you receive SMS?
Can you send MMS? Can you receive MMS?
07-20-2022 10:00 AM
Android
07-20-2022 09:59 AM
Didn't work and it is Android
07-20-2022 09:46 AM
If iphone using imessage then have you checked that mms is on? If iphone can you send pictures to other idevices?
07-20-2022 09:46 AM
@Willaug56 let us know how it turns out
if it does not work, tell us if this is an Android or iPhone and will advise further
07-20-2022 09:32 AM
I was able to before on the same phone so I will try the reset
07-20-2022 09:29 AM
@Willaug56 'ou used to be able to receive and send picture, but was it on another phone? or you have the same phone?
did you have Mobile Data enabled?
If you have already enabled Mobile Data, try again sending a smaller picture
If still fails, you can try to Reset Network settings and see if it helps (Please note resetting the network setting, your saved Wifi connections will be gone too and you have to rejoin those Wifi networks)
07-20-2022 09:25 AM
@Willaug56 hi you need data enabled to send or receive mms
