SMS Messages don't work
Icebane
Hello,
I've been on this network since Aug 5th but I just realised why nobody is responding to my text messages.  They aren't actually being sent and none come in either...  How do I check my SMS/MMS provisioning or refresh my eSIM profile?  What else can I do?
1 REPLY 1
hi @Icebane
you removed the old carrier sim card?  make sure it is removed or the old esim is disabled
Also, Reset network settings and test
if same, submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
