SIM
wayneupper
I ordered a SIM May 1st but it has not arrived.
Hi @wayneupper ongoing problem with sim order
https://productioncommunity.publicmobile.ca/t5/Announcements/Ongoing-Issue-Delayed-SIM-Card-Orders/t...
Please submit a ticket with agent to check the order status
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@wayneupper  since it has been over 10 working days, I would suggest you submit a ticket to customer support to inquire and let them know.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
wayneupper
order number 342316
