07-01-2024
04:30 PM
07-01-2024
11:14 PM
computergeek541
I’m planning to get a new phone that is only eSIM compatible. Currently, I have a phone that can only do SIM. Is it possible to transfer my number into that eSIM/new phone? Do I need to keep my SIM card activated?
07-01-2024 04:33 PM
Thank you for the quick reply! I hope you have a wonderful day.
07-01-2024 04:32 PM
Very easy to move to eSIM
When you have the new phone that has eSIM function, just download the app on your new phone. Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install and follow the prompt to complete and purchase and install eSIM on your device
After the esim is setup, the new phone will works with your phone number, the old physical sim card will be voided
