Monday
Been over 5 hours since porting number from Rogers and now have PM and Rogers service. Unable to call or send texts from PM number.
Monday
Try restarting the phone. If your Rogers SIM card is in the phone, confirm you no longer have service. If you do, the port didn't work. If it doesn't work, remove, insert PM sim, or if eSIM, make it primary service and then reset your network settings and reboot. If you still need help, contact a CS agent. May take a long time though
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
