SIM not activated yet
03-01-2019 06:51 PM - edited 01-05-2022 03:33 AM
03-01-2019 08:40 PM
I find similar situation ,I ported by number from Virgin still both Sims are active it's been 8 hours .
I activated my plan with PM. how long does it take to make the Virgin network sim invalid
03-01-2019 07:04 PM
@ajay2504 check if you were charged for activation. If yes, the activation might have gone through properly or partially. Insert the sim in your phone and see if it works. If you weren't changed, sim card should still be valid so try activating again. This time try using incognito/private browsing mode.
03-01-2019 06:57 PM
@ajay2504Did you activate in store, or yourself (online)? If you did it yourself, did you encounter any errors? If payment was by CC, do you know if payment was taken?
03-01-2019 06:57 PM
@ajay2504 wrote:I bought $30 per month plan but the sim card is not activated yet. What to do for sim card activated?
Did you get any errors or time out messages when you activated here @ajay2504 ?
https://activate.publicmobile.ca
03-01-2019 06:55 PM
