SIM card
Vipyul
Spoiler
Hi I bought new sim two days ago
still not showing sim range they said will work within few hours but still not
why it’s so irritating now
Vipyul
Hi I got from store and the guy activated
it’s brand new sim so there is no replace convern with old one
I don’t have sim before
@Vipyul   you got a brand new SIM card to replace old sim or to activate?
if you are replacing old sim , please login to My Account and request Change SIM card and select one of the option to receive the security code
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/change-sim-card/https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/change-sim-card/
If you are activating, then go to https://activate.publicmobile.ca/ to activate
Vipyul
Hi I bought brand new sim and showing No sim I am so disappointed please help thx
@Vipyul  can you provide us more information
You get a new sim card to replace an old one?  If so, did you login to My Account and request Change SIM card and you entered the security code?
If you did all that , what is the error message on the phone?  "No SIM"?  "SIM not provisioned"?  or "No Network"?
