SIM card
Morgan20
@CS_Agent I just started a plan with you guys a couple days ago and love it! My brother told me about you guys and he had ordered a SIM card in the mail to get the $40 plan with 4.5 GB, which ended yesterday. But the SIM card still hasn't arrived, is it possible to get a rain check for him?
drmartin
Yeah, really bad timing.  Just wait for the next deal, the new $40 plan is almost the same, just 2 GB less data.
@Morgan20
There are a couple of build your own plans that does offer some promotion presently:
$40 for 4.5 GB at 3G speed ----> now available for $45 for 4.0 + 1 GB
$45 for 6 GB at 3G speed-----> now available for $45 for 4.0 + 1 GB
$50 for 8 GB at 3G speed (with US calling) ---->  $40 for 6.0 + 2 GB
Your brother might want to consider.  If better deals come in the future, you can always change to new promotion.
KMG
Unfortunately, it's not possible.  The $40/4.5GB has expired for the time being, so you would need to select a plan that is currently available.
That being said, chances are that there will be more promotional plans coming in the future, so keep an eye out.
