SIM card
BeeC
cannot activate a new account, problem SIM card already in use
7 REPLIES 7
@computergeek541
People might assuming that online mean on your computer or laptop. That is why I made the comment but it is a good point about the app being online.
@BKNS27 wrote:
@BeeC
Are you activating it on the PM app on your phone?
It can’t be done online anymore.
All activations must be done online.  Using the app is an online activation and requires an internet connection.
@BeeC
edited by computergeek541: crossed out incorrect information while preserving the solution about how the app must be used for activation
BeeC
bought from amazon.ca
@BeeC
If it has been activated, return to the place of purchase then pick one up at a Telus/Koodo store for $10 or from Amazon for $4.99.
You can only activate the SIM on the PM app.
@BeeC is that a brand new sim card never been used before?? Sim card can only be activated once
Boki
Hmmmm. Did you buy brand new card from reliable source?
