06-09-2021 07:37 PM - edited 01-06-2022 02:51 AM
So I have my new sim card and my old sim card, but I don't know how to get my information over to the new sim.
06-09-2021 09:21 PM
06-09-2021 08:45 PM
@DaltyG wrote:So I have my new sim card and my old sim card, but I don't know how to get my information over to the new sim.
Just checking...did you lose your old SIM?
If so, then yes, you will need to contact Moderators to change your account and phone number to the new SIM card.
But, if you have your old SIM card and if you are just changing phones you should be able to remove the old SIM card and re-insert it into the new phone. Depending on the SIM slot of both phones...it may be the same size OR smaller or larger which an adapter can be added or removed to than make fit.
Just wanted to put that out there, as some people are not aware of this.
06-09-2021 07:39 PM
06-09-2021 07:38 PM - edited 06-09-2021 07:41 PM
Only one way to you fix it explanation to moderator Team and the are nice service the will 100% help you
you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
for more information visit HERE
Good Luck
