SIM card replacement
Tim-Regnier63
Says I am unauthorized what do I do?
2 REPLIES 2
hairbag1
@Tim-Regnier63
what exactly are you trying to do. Did your Public Mobile sim fail or...?
slusagm
@Tim-Regnier63
are you changing sim card.  You should be able to replace it.  What exact error you got? Post screenshot
but if it is a login issue, you can ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
