SIM card problems
deepg82
Hey,
I'm having SIM card problems. I've had the same SIM card for years but it's giving me problems now. Sometimes I can't connect to the network. None of my calls go through (they don't connect) and I can't use my data. If I restart my phone, everything works fine. My phone is a Xiaomi Mix 3.
Do I need a new SIM?
gpixel
@deepg82 did you recently update the software on your device?
reset your network settings
open settings
scroll down to system
tap on reset options
tap reset wifi,mobile & Bluetooth
tap reset settings and restart
contact customer support mods before you purchase a new sim
click on the question mark chat bubble to the bottom right of your screen
type "no service"
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
Jb456
If you do end up buying a new SIM card you can easily change it in your account.
Click change sim card. Green arrow on picture below.
That's all that is required to transfer your account to a new sim card.
Triguy
Try wiping the sim with a clean cloth and reinsert your sim.
Jb456
Do you have another phone to test your SIM card in to see if it's a device issue?
