07-04-2022 08:53 PM
My iPhone says that my SIM card is not supported. What should I do?
07-04-2022 10:06 PM
If you purchased the iPhone 6S privately, you phone is locked by a carrier from the previous owner of the phone.
You will need to go into your Settings to see what carrier have locked your phone.
Go to Settings>General>About>Carrier Lock (scroll to the bottom of the page).
If it is locked, it will show eg. Rogers, Bell or another carrier other than Telus.
If this is the case, you need to contact that company to have it unlocked or go to a mom & pop cell repair shop and pay to have it unlocked.
07-04-2022 09:16 PM
No this is my first SIM card. I’ve never been with anyone else
07-04-2022 09:14 PM - edited 07-04-2022 09:16 PM
@Rachel2003 , I believe your phone is locked to a different carrier. You will need to figure out the original carrier source for this phone and get them to help you with unlocking it so that it will work on the Public Mobile service. Currently the phone will only work with the source carrier. This link should help to explain the situation.
07-04-2022 09:02 PM
What do you mean by that?
07-04-2022 09:00 PM - edited 07-04-2022 09:02 PM
@Rachel2003 wrote:No it’s a 6s
@Rachel2003 well somebody had it somewhere else, connect to itunes and download latest carrier updates
07-04-2022 08:59 PM
No it’s a 6s
07-04-2022 08:58 PM
@Rachel2003 is it a new phone?
07-04-2022 08:57 PM
no I’ve never had an account with anyone before
07-04-2022 08:56 PM
@Rachel2003 hi it sounds like your phone is locked toyour previous provider contact them for unlock instructions
