07-19-2020 03:17 PM - edited 01-05-2022 12:10 PM
I can’t get thru to a moderater to get a ode to unlock it so
07-19-2020 03:30 PM
@Shayshay , the moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
