03-04-2016 07:26 PM - edited 01-04-2022 02:32 PM
Hi all,
From researching on public mobile.. it seems that in addition to the cost of having a voice/text/data plans.. one would also have to pay an additional $10 fee for being able to use the SIM card every month.
Is this correct?
So for example - if I were to choose the 90 day plan with unlimited talk (province wide) along with unlimited texting (Canada wide) and 1GB of data - the total cost would be $90 plus $30 (per month for SIM card). So to be able to use the phone on Public Mobile - the total cost would be $135.60 (with taxes on Ontario) for 90 days. Is that right?
thanks!
03-06-2016 04:18 PM
Hi @crackerjack. I had a look at that article and it was from back when PM first re-launched just over a year ago, and I don't quite think they understood how the plans worked at the time. I can see how it would be misleading. I'm glad you asked here. 🙂
03-05-2016 08:44 AM
03-05-2016 06:47 AM
Hi all,
Thanks for the quick responses! Here's the link that mentions the $10 fee:
Is there some way for me to say that my "issue" is resolved?
03-04-2016 09:48 PM
Hey @crackerjack,
Martin's hit the nail on the head.
Furthermore, I would like to reiterate that for the plan you mentioned, you will pay $90 every 90 days plus tax.
If you sign up for auto-pay, you will get $6 discount every bill ($2 every 30 days).
Also, this is worth repeating.. everything on the 90-day plan would be for the duration of 90 days. So the 1Gb will be your data allowance for 90 days. Many people tend to misinterpret this point, so I thought I clarify.
03-04-2016 09:45 PM
Hi @crackerjack, as others have indicated, the $10/month fee is built into the cost of the plan, rather than on top. So the plan you mentioned would be $90 + tax, and NOT $90 + $30 + tax. I believe Ontario has a 13% HST tax? So that would make it $101.70 total for 90 days of service.
03-04-2016 08:42 PM
No... that's not correct
03-04-2016 08:08 PM
@crackerjack Not true at all. Where are you seeing this $10 monthly fee to use the SIM?
03-04-2016 08:08 PM - edited 03-04-2016 09:18 PM
Hi @crackerjack,
There is no fee for ordering or using a SIM card.
The basic fees are $5, $10, and $25. They are for plans that are 10, 30, and 90 days long, respectively. Add to the respective basic fee the cost of options, plus any add-ons, less the discount. (See the bottom of the plan builder where the charge is.)
I hope that the above information will allow you to correctly calculate what your 90-day plan would cost. Plus, the plan builder has a perfect record in calculating costs with different options involved.
Since you mentioned 1 GB of data and 90 days, please note that the 1 GB is for the ENTIRE 90 days, and not just for 30 days.
FYI.
