12-28-2025 09:45 AM
Hi, I have eSim in my phone and wonder if I can order a physical SIM card to be able to use in my other phone in case I misplace my esim phone; ie have two points of access to my subscription eSim and SIM? Thx in advance! PM101
12-28-2025 12:45 PM
Nice, lots of options, THANKS for your help!
12-28-2025 10:25 AM
Yes , you can change it back to a physical sim
get a Public Mobile sim card from
Once you got the sim card, you can update the sim card number from either the PM app or My Account via the browser:
If you are updating via Public Mobile app
login and go to Account page
(If you are unable to login as you don't have a phone to receive the 2FA code: On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email)
click Change your Sim card and update your sim card number there
To update it from My Account via the browser:
login My Account to request Change Sim card
Go to Profile page, click on the Pencil besides the sim card number, follow the steps to enter the new sim card number and complete the change sim card request
(or direct link: https://myaccount.publicmobile.ca/en/account/profile/change-sim-number )
12-28-2025 10:22 AM
OK good to know Softech, many thanks for your help! Can a eSim be swapped for a physical SIM card?
12-28-2025 09:53 AM - edited 12-28-2025 09:54 AM
@pm101 , sorry you cannot
Only one sim can be active in an account at all time, whether eSIM or physical. The newest sim activated with the account will be the one used, the older one will be voided after the new one is activated
