SIM card Not working
mariajime
My Sim Card doesn't work. I am using it on a different phone but this phone is unlocked and brand new. it says NO SIM CARD- Emergency only. What should I do?
2 REPLIES 2
JL9
Based on the solution I am assuming your phone is blacklisted? Did you buy it used (kijiji, etc.)
Hi @mariajime   Check if the phone is blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
