SIM Delivere
velenahouse
Hi. I place a SIM online order on May 2, 2023 and received an order number were it says SIM will be delivered within 5-10 business days. Todays is May 16th and I haven’t received my order.
hi @velenahouse it is less than 10 days, your sim should arrive sometime this week
But if you want, submit a ticket and ask for update
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
LitlLdy
@velenahouse ,
If you want to wait for your SIM card to be delivered & it goes past 3 weeks please submit a support ticket to CSA (Customer Support Agent) for help with your missing SIM card.
  • Get help with your service or account by starting a conversation with the virtual assistant, SIMon. It can help you submit a ticket to the Customer Support Agents. This method uses the ticketing system for a faster response time. Click here to get started and type Customer Support Agent,then select Contact Us, then select the topic that matches your request.
  • Alternatively, you can send a private message to Customer Support Agents by clicking here. This method takes longer to receive a response back. You’ll need to be logged in to your Community account for the link to work.
Watch for a response back from a CSA in your Community private mailbox at the top right of this page which will be indicated by a number on the small envelope icon 📩to the left of your Community avatar.
LitlLdy
@velenahouse ,
SIM card orders can take up to 3 weeks to receive from Public Mobile that are delivered through Canada Post with no tracking. It took over 3 weeks to receive mine. Some get them much faster! Sorry.
If you need one faster you could try getting one at a Telus, Koodo, or Mobile Klinik store then set up your account online at home. Also, I find using a browser in private / incognito mode allows the setup to go smoother. If you purchase one in store you can save the extra one that you purchased on here (once you receive it) to pass on to someone else that may want to sign up or keep it as a spare in case you lose one.
https://www.publicmobile.ca/en/nb/store-locator
