04-06-2022 08:28 PM
I ordered a new SIM card - Triple Punch SIM Card × 1, but up to date, I have not received the SIM
Got notification on Mar 23/2022 that it's been shipped but i have not received it
The order number - 288176
04-11-2022 12:07 PM
Thanks a lot
I have contacted the CSA team
Much appreciated
04-06-2022 09:25 PM
Unfortunately getting it shipped by PM is takes longer than everywhere else by a mile and then some.
04-06-2022 08:59 PM - edited 04-06-2022 09:01 PM
@Shola Current promotion work in in-store activation as well as online self activation. So, without worry being not able to get the promotion, you can try to activate in a local mobile store. Most stores will give out free SIM if you activate with them. So, just check it with your local store and activate there.
04-06-2022 08:51 PM - edited 04-06-2022 08:52 PM
If you need it sooner, go to Walmart or London Drugs, or another mobile merchant to get one.
If you live in the Toronto area, check out Contact us – Canadian Cell Supplies for locations - quick and cheap to buy it there.
It's always a good idea to have a spare SIM anyway (i.e. if you lose or want to refer someone else here), so consider getting it this way.
04-06-2022 08:34 PM
@Shola wrote:I ordered a new SIM card - Triple Punch SIM Card × 1, but up to date, I have not received the SIM
@Shola - you can check on the status of your order/shipment by checking with CSA agents.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
