10-15-2017 04:46 PM - edited 01-04-2022 02:46 PM
Hi, I am having problems activating my new SIM card. First, I tried to port my land line number and it did not work (Videotron). Then, I read on the forum that it is easier to chose a new phone number and then transfer my current phone number. It didn't work either. Could anyone help me please?
Thanks 🙂
Juan
10-16-2017 09:16 AM
Good morning @juanr1912,
Thank you for contacting us and for sharing your experience!
I'm pleased to say that my colleague was able to assist you and send you a confirmation message. Please view it 🙂
Welcome to Public Mobile,
Mary
10-15-2017 10:02 PM - edited 10-15-2017 10:02 PM
@juanr1912 Contact the moderators as suggested. I suspect your account has been partially activated and is awaiting the port-in of your landline, which will continue to work until the port-in finishes. DO NOT cancel your landline contract; that happens once the trasfer has finished.
Can you call out with your PM SIM installed? If not, what message is displayed on your phone after rebootimng with the sIM installed?
Can you still use your landline?
10-15-2017 08:29 PM
Hi Juanr1912,
I believe porting landline to wireless might take a couple days.
I suggest you PM a @CS_Agent to find out the status of your activation before attempting to activate again.
Hope this helps.
10-15-2017 05:10 PM
@juanr1912 Sometimes when the system is under some work, it throws out errors. I suggest you to try again later today.
Here are some solution i was able to search if you still get that error later on:
https://productioncommunity.publicmobile.ca/t5/Self-Serve/Generic-Error/m-p/124641
10-15-2017 04:57 PM - edited 10-15-2017 04:59 PM
It still does not work while in Incognito mode. Here is the error message I get. It happens right after I choose my plan.
Generic Error
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page.
10-15-2017 04:50 PM
@juanr1912 Are you getting any error when you try to activate?
Try using incognito/private browsing mode.
