07-10-2022
03:00 PM
07-11-2022
02:00 AM
computergeek541
I believe my Sim card has been activated as I received a text from public saying welcome and that I will receive email confirmation soon. Do I now replace my old SIM card with the new one from public, or wait until the email has been sent?
07-10-2022 03:07 PM
@H4ttieF1tz put your PM sim card into a phone. Test calling your number and see if PM sim rings
It might not ring right a way, no worry, porting could take another 2 hours after you replied YES. So, reboot your phone with the PM sim inside every 30 mins and try incoming calls again
07-10-2022 03:06 PM
@H4ttieF1tz yes you can 😀
07-10-2022 03:04 PM
hello, I am porting a number and my old provider texted me asking for approval for the transfer which I did. So I can put my public SIM card in now?
07-10-2022 03:02 PM
@H4ttieF1tz hi are you porting a number? if so leave old sim in until you receive transfer request reply yes and then you can put your public sim in
