SIM Card Replacement Not Processing
JohnD56
When attempting to purchase a replacement SIM card, the site refused to process the payment. The error message stated that while my card had processed successfully, the transaction would not process, and to contact support. A second attempt was the same.
I used the credit card attached to auto-pay on the account, and tried to process the transaction on the mobile website.
1 REPLY 1
hi @JohnD56
don't buy the sim card from PM site if they didn't charge your credit card, you can buy it cheaper from Amazon
https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG
but in case they charged you, ask PM support agent to check and help
 you can submit  ticket by direct message:
