SIM Card Pin
SirSexyman
May I ask if anyone actually knows what the standard SIM Pin is on a Public Mobile SIM Card? I would like to enable a SIM Pin but do not want to PUK my SIM as you only get 3 attempts. Please only reply if you know what the PIN is by trying on your own SIM. Thank you all in advance.
SirSexyman
Thank you.
GinYVR
The default is 1234. It was mentioned in past threads. I just tried it.. BTW the 3 tries resets after each successful entry.
geopublic
@SirSexyman  From what I've read on this forum the standard default code is 1234. If you do not want to chance it you can contact a moderator to confirm. To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderator Hours: Monday-Friday 8 am(Eastern) to 12 am (Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm (Eastern).
