SIM Card Blocked
habpierre
Good day. Can anybody help me out? My phone says SIM Card blocked. Help?
2 REPLIES 2
cin7
1. Try contacting the Moderator Team for a PUK code - https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
2. If this doesn't work, your fastest solution is to purchase a new SIM at Walmart, K Mobile, or WOW mobile. You can change the active SIM in your self serve account.
ShawnC13
That is the message you are getting?  What type of phone are you using and is it unlocked?
