06-07-2022 07:46 AM
My SIM IS LOCKED I NEED VODE PUK PLEASE CAN U HELP ME
My Account
06-07-2022 03:24 PM
@Maryam77666mm6 what was the exact error message? There are couple unlock codes depends on the meeage. If it is a carrier unlock code you are taking about, you need to call your previous provider. Which one was it?
06-07-2022 02:49 PM
Can you send me the number please
06-07-2022 12:13 PM
It is more likely this issue but you cna call your previous carrier and get pretty easily
06-07-2022 08:00 AM - edited 06-07-2022 08:01 AM
if it is the SIM card puk you are looking for , you can open ticket with this direct link :
06-07-2022 07:48 AM
@Maryam77666mm6 hi did you just bring your phone from another carrier? if so you need to contact them to unlock your phone
