Referral bonus
PubPaul
Can I get the referral bonus even after I’ve just set my account hours ago?
PubPaul
Thanks
PubPaul
Thanks!
JL9
Did you use a referral code? Sounds like you didn't..if not do you have a friend or family member that is a PM customer,. You can request a CSA to manually add it for you.
@PubPaul
You should see the $10 referral bonus if you used a referral code or if someone used your referral code, you will get 1 point/month.
An additional $5 for 5 month credit if both of you signed up on PM by June 6/22.
pkaraa
As soon as you create your account and it gets activated you ll get your referral code to share with friends and family.
hairbag1
Did anyone give you a referal code to apply when you activated your new PM account. If they did and you forgot to apply it...just contact a Customer Support Agent and they'll help you out.
Watch the little envelop icon on top right side of this page will be highlighted when they respond to you.
edit...
Activations on and after May 20 and before Jun 6 are eligible for the special $5 x 5 months bonus for BOTH the referrer and the referee
