Roaming
CelticBoy
Tha
 Thank you to 'all' that will help
1 REPLY 1
@CelticBoy if you don't travel to US, you can leave roaming off
But PM is prepaid, you don't get extra unexpected charges even you have roaming turned on as you won't be able to use roaming without getting a US roaming add-on purchased ahead or a Canada-US plan
