04-14-2022 01:09 PM
Hello , if I add the roaming bundle, does the ten days start when I add it, or when I turn my phone on in the United States?
Add-Ons
04-14-2022 01:58 PM
Do it on the wifi at the airport when you land.
T-Mobile seems to be the best option due to the 3G issue although AT&T may be better depending on where you go.
04-14-2022 01:22 PM
IH @jennawilliams1 Yes, the 240 hours starts right when the purchase is completed. Wait until you really need to use the roaming
When in US, make sure you manually select T-Mobile and AT&T as the network to use
04-14-2022 01:12 PM
