04-06-2023 05:07 PM
How does redeeming and earning work? and can you save your points up to redeem later?
and when you redeem does it just add a balance to your account?
04-06-2023 07:32 PM
You must redeem points when you have accumulated enough to do so. You do not earn points on point redemptions (ie. $15 bill credits). There are significant discounts on nearly all add on redemptions ranging between 25% and 50% off the regular purchase price. You may find these threads helpful in regards to points....
04-06-2023 05:11 PM
here's a bit of reading for your pleasure...
https://www.publicmobile.ca/en/bc/get-help/articles/Public-Points-Rewards
04-06-2023 05:08 PM
@Ckk_2194 wrote:How does redeeming and earning work? and can you save your points up to redeem later?
Points only get redeemed when you choose to do this. Until then, the points will accumulate.
