Rewards
Filsinger1956
I currently have a 3g - 25.00/month plan. I am looking to upgrade to the 4g - 40.00 plan. If so, are my rewards/benefits carried forward the new plan?
Filsinger1956
Thanks!
hairbag1
@Filsinger1956...
the $25 plan only has 1GB of data per 30 days.
PM is currently offering $40 for 15GB (4g) per 30 days.
Meow
Yes, rewards will stay as is. Rewards are tied up with your Account not plan so you can change plans as often as you need/want.
Quigley
@Filsinger1956
No worries about losing any of your rewards or benefits.  I got to keep all of mine when I switched to that plan recently.
Outdoorsman
@Filsinger1956 hi yes they are tied to your account not your plan , just don't change to new rewards system
