Rewards
billyjean007
How do you earn a top 50% badge
1 ACCEPTED SOLUTION
Accepted Solutions
HALIMACS
@billyjean007  You earn this by participating in the Community by asking questions, posting replies with proposed solutions, acknowledging posts with Bravo's, and generally being helpful.  I'll give you a Bravo to help you along!!!
For more information, follow this link and scroll to the section titled, The Community Reward:
https://www.publicmobile.ca/en/on/get-help/articles/reward-rules
14 REPLIES 14
darlicious
@billyjean007
You just started with your post....
HALIMACS
darlicious
@billyjean007
Lol.....but you have....when you are a new member you come to the community and hang out. Read some threads, ask some questions. Bravo posts that help you learn, award solutions when you get your questions answered. Use the search bar to learn the answers to other users questions and help them if you find the answer. ( A checkmark indicates a solution which is usually the answer but not always....find the same solution to the same question a few times and then you know for sure.)
So just do this when you have time to hang out and your on your way to contributing to the community that the secret formula with 11 herbs and spices that calculates your level of participation and awards the community rewards each month. Welcome to the community!
Triguy
You can earn up to $15 every 30 days for the Community award.  Read up on past posts and solutions.  Helping others is more rewarding then the monetary award.  You can save more money by referring friends and family with the Referral award.
Staliger
@billyjean007 in short, be active on this forum and you can earn up to 15$ per month. Answer questions, help people, and add value.
Helpershelper
@billyjean007
Well it’s based on certain calculations but that should be the reason you’re on here. Keep in mind if you get that badge you will only earn $1. You shouldn’t spend all your time on here just to earn $1 but to share your knowledge or to occasionally check the forums to see if others have the same problem as you for example or for something else.
gpixel4
@billyjean007 it's hard to say what the quota is for top 50%. for some users, all it took was one post and some Bravo's. others have had the same and not qualified. I think as a new user, it doesn't take much, but as the months go on you will need to contribute more. I think it's also dependant on the total contributors in the month.
I believe you're correct, @gpixel4 .  The badges for top contributor levels apply for activity during the prior calendar month.  I take that to mean that if someone maintains a similar level of activity month over month on the Community, that doesn't mean they'll maintain the same contributor level as it's based on everyone's activity in the community for that particular month.
Is that how others view it?
@HALIMACS
Yes.....the amount of users and the level of activity affects the level of participation and the amount of rewards in total that are awarded each month. See here for some insight.....
https://productioncommunity.publicmobile.ca/t5/Community/Community-Rewards-Allocation/m-p/578760#M83...
