Rewards
Angie3
GGPlayer
Just show the payment history to the mod. It should refund $2 if it's missed this month.
@GinYVR wrote:
@Angie3Can you check if you had changed your plan or do a Lost / Found during the previous month? Because if so, the $2 will be deferred till the next month.
It would appear on your account as a$4 credit for next month. If only $2 shows or none at all you need to speak to a mod. You can also reference your accumlative reward since joining by clicking on my rewards section in your account. You will be able to compare that to your transaction record to see if it was applied or not.
jonfirlotte
I would ask the moderator team about this, this could be a glitch.
GinYVR
Jb456
Stay Safe!
