Rewards
Zkee
Hello!
I converted 15 points from my rewards to data and I have gotten an email confirming that it would receive it within 24 hours but it's now more than 48 hours and I am still yet to receive it. Kindly help.
Thank you.
Zkee
Tuesday. No i didn't restart, will try that now. Thank you.
TheSterlinger
When did you convert the points? Did you restart your phone?
Also check the Usage Breakdown on the Overview page to see if the data redeemed is there.
slusagm
Isnt it 20 point for $20 now?
Ask PM to check
 Since you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
