Rewards
Redicknuff
I’m thinking of changing my subscription plan. I currently have the $25 per month plan, and I have $10 in rewards savings per month. (Pre-Authorized Payments, Loyalty, and Refer-a-Friend) My question is, if I decide to switch from the $25 per month plan (1GB of data) to the $39 per month plan (20GB of data), will I loose my current rewards? Or will I still get the $10 per month savings?
Thanks!
Chalupa_Batman
Just an update @Redicknuff
If you look up top you'll see a banner. This is the link in the banner. So the plan you want is $39 a month for 20GB of data. This offer above is $40 a month (but needs 3 months payment at a time) and you get 40GB of data. So basically $1 more than the plan you want with 20GB more data. You HAVE to see the value in that offer!! 🙂
https://subscribe.publicmobile.ca/en/on/activation/plans/40GB-5Gspeed2
Chalupa_Batman
Hey @Redicknuff
Don't worry about it. You will never lose your rewards. You will only lose them if you switch to the new reward system. NEVER change!!!
EDIT: Read this. This plan is MUCH better for $5 more!!!  $39 20GB vs $45 50GB!!
https://productioncommunity.publicmobile.ca/t5/Announcements/Limited-Time-Sale-60GB-Canada-US-plan-f...
