Rewards
ktriggs1
If I switch plans does my rewards program stay the same or does it switch to public points?
1 REPLY 1
JRod
@ktriggs1
Switching plans will not have any effect on your current rewards, you will continue with the Legacy program when you switch plans. The only way to lose your legacy rewards are if you manually opt into the points program or if you close your account. Never switch from Legacy to points.
