05-24-2023 12:02 PM
So I accidentally clicked through to the new reward point program.
They "can't" reverse it, which is horse crap.
I rather give my more of money to another carrier than to stay with one that makes their customers pay for their mistakes.
Does anyone have any suggestions on a better carrier?
05-24-2023 02:17 PM
@SweeneyRG - did you click the box to 'agree to the terms and conditions' ? Or, did they take that step away?
05-24-2023 12:49 PM
To answer your question.. maybe Lucky mobile? Same low-tier as PM but under Bell i believe. Or Koodo if you'd like to stay in Telus network.
05-24-2023 12:48 PM
We have been warning people when they change their plan NOT to click on switching to the new Points system.
The only good thing is you can redeem $15 credit off your bill if you collected 15 points and also the Giveaway contest for Points member.
05-24-2023 12:31 PM
@SweeneyRG wrote:So I accidentally clicked through to the new reward point program.
@SweeneyRG , unfortunately not! 😥 I had to select to the box to agree to the terms before I switched to the points program , so I lost my rewards program that I have been with since 2019! Nothing the CSA’s could do about it! I put up a big fight over it!
05-24-2023 12:28 PM
once you've opted out of Rewards in favor of Points...you can't go back, I'm afraid.
Although Points aren't that lucrative...they do have some value. I suggest you stick around and just see if you can collect enuff Points to take advantage sometime.
05-24-2023 12:10 PM
Sorry, you cannot go back to monetary rewards anymore.
Selecting points is irreversible 😞
