Rewards change with new plan?
I'm on the old rewards system, not the point system.
I'm hoping to switch plans to the new $39 for 20gb.
I think if I switch plans, my rewards will stay the same, but I figured I'd double check and make sure!
Thanks!
hi @Anonymous
no change to your rewards system with plan change
@Anonymous  Be sure to change on next renewal and not immediately so you don’t loose out in your current cycle
Thank you kindly
@Anonymous
Make sure you don’t click on switching to the new Points system!
If you didn’t, you are OK and will stay with the old Rewards system.
@Anonymous  No you get to keep your old rewards I can confirm , check it out
