04-13-2020 02:46 PM - edited 01-05-2022 10:21 AM
Hello Oracles,
I want to bring an issue to your attention.
So after receiving that email on my last thread one of our kind community members said you should change your password. So I went to do that. But it came up that is didn't work.
So, I logged out then went to log back in and my original password wouldn't work. Tried it 3 x. Then I tried the password I had switched my account to and now that works.
So there might be a bug in the system that gives you the alert even when it has been successful.
04-14-2020 06:49 AM
Thanks good to know this @Naepalm .
04-13-2020 03:28 PM
@Naepalm Thanks for the heads up on this issue. 👍
04-13-2020 02:54 PM
@Naepalm wrote:the only issue with go through SIMon is there is no way to explain the issue before the moderator s talk with you.
In that case you can send a private message directly to the Moderator_Team.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
04-13-2020 02:52 PM
04-13-2020 02:49 PM
Submit a ticket to a moderator by clicking on the question mark on the bottom right. They could check to see if there is a glitch with the system.
