03-30-2023 11:32 PM
03-31-2023 12:44 AM
Yes I understand but it says there is a problem when I submit the password change. It doesn’t go past that screen.
03-30-2023 11:35 PM
for resetting password, first try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if that does not work, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
03-30-2023 11:34 PM
@PG3 wrote:Could I get assistance of changing password through live chat.
Sorry, but there is no live chat. Chaning your Self Serve password doesn't require the help of a customer support agent and can be done from within the account. If you're unabled to get into your account, please first try the password reset option (if you haven't arleady).
