Reset password
Charoucinha
Hello... I’m trying to login but forgot my password and forgot my security answer. Seems like there’s no other way to reset password without knowing the security answer. I need to change my credit card information in order to proceed with payments. Can you help please?
Thank you,
Ana
geopublic
@Charoucinha  You need to submit a ticket and be able to prove that you are the account holder.
Staliger
Thank you,
Ana
@Charoucinha Contact moderators: click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
gblackma
@Charoucinha You should contact a moderator and explain your situation.  Click on the green questionmark in the white circle at the bottom right of your screen . This connects to the autobot Simon.  Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket ). If you are unable to reach them this way, use this private message link to contact them directly  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Thank you,
Ana
