Removing CC info
PremalKumar
Its not allowing me to remove CC info.
Its just generate negative opinion.
CSA_PM
Customer Support Agent
Hello @ PremalKumar,
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
hairbag1
@PremalKumar
just dm Customer Support to request your payment card info be scrubbed from your acct...
slusagm
you really want to remove the credit card?  if you removed it, you will have to pay by vouchers, or unless you are planning to leave
and yes, you cannot remove credit card yourself, you need to ask PM to remove it for you
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
