Refund since subscription cancelled
Annik2
I need to receive a full refund since my service never worked. Please confirm by email asap.
2 REPLIES 2
hi @Annik2
what was the issue? eSIM? what phone you have?
check with PM support agent first, they will try to help and get it working.  If they cannot help, then they will help with cancelling the service and refund
you can submit  ticket by direct message:
slusagm
if you setup the service and it never works, PM will help and arrange refund
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
