5 hours ago - last edited 3 hours ago by computergeek541
3 hours ago
If it's activated, then you should have service. One thing you can try is rebooting the phone. Also, sometimes SIM cards need to be reprovisioned. That basically means, turn off your phone, remove the SIM card, place it another turned off cell phone and reboot. That somewhat wakes it up. If that doesn't work, create another ticket.
4 hours ago
I paid. I activate the service and nothing is working.
4 hours ago
This is very bad service
5 hours ago - last edited 5 hours ago
@Ashkanksh wrote:Oh. I thought this is support. How can I remove this post!?
Click on the arrow in the box and click edit and the click on picture to delete
This is your mailbox, they will reply here once you create a ticket.
5 hours ago
Hello @Ashkanksh
You need to create a ticket to get a credit for that. Here's how. Also, please remove the receipt from these forums. These are public forums, not private.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
