03-08-2024 09:30 AM
03-08-2024 09:36 AM
HI @Emma1234
PM is prepaid and usually do not provide refund. But if the service does not work on activation, they will usually help. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
For your esim, did you check if it is installed? enabled? set as primary and "Turn on this line" is set?
