Referral
03-26-2024 03:28 PM
Hello! I forgot to input who referred me to Public Mobile. Can I still get their account credited, or whatever they get?
thank you
Rewards
03-26-2024 03:40 PM
@pbigattini No worries , even thou things supposed to be done on activation support team is typically pretty understanding and will help add it for you after the fact just
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
03-26-2024 03:31 PM
HI @pbigattini
support agent can add it back for you. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
