05-07-2017 07:28 PM - edited 01-05-2022 02:03 AM
Hi
I signed up with Public Mobile in November 2016 and shortly after I referred someone and it's been several pay periods since but the referral reward is still not showing. Is there any way to get this looked into and rectified?
Thanks
05-08-2017 04:21 PM
05-08-2017 04:15 PM
@Samianauman wrote:
As willam mentioned if you don't see phone number in there for the person who used you as a referral then even if you contact mod they won't be able too add manually
Yesterday someone forgot to add my number but he did send a private msg to add me but it's too late if they forgot to add at first place then it's a done deal can't be added once the account is activated sorry
There's a difference between "person used it on sign up but it's not showing up" and "person forgot to use it on sign up". Hopefully the mods are able to tell the difference.
05-07-2017 10:06 PM
05-07-2017 09:53 PM
@Fulgore wrote:I didn't get any text message that the referral was successful I just was told by the person that referred me that they used my phone# when signing up
If you go into your account, rewards tab, do you see the referred number there. Click on the little triangle pointing right to reveal. If not there, maybe you weren't used as a referee.
05-07-2017 09:46 PM - edited 05-07-2017 09:47 PM
05-07-2017 08:02 PM - edited 05-07-2017 08:17 PM
Also if a person fogot to add your number when activating sim then even mod won't able to add you as refer later on its hit and miss option.
05-07-2017 07:57 PM
@Fulgore, as mentioned private message a mod with the info as stated above. But also are you sure that the person you referred entered your number and if they did that it was done correctly at the time of activation that is the big thing to make sure of as well.
05-07-2017 07:49 PM
@Mana wrote:
When you referred that person a few months back did you get a text message confirmation that you have successfully referred someone?
If the referral is successful, you are supposed to get a text message confirming it.
From my personal experience, the messaging was hit and miss. Some referrals did not result in any text being sent to me. All my referrals are account for in the credit department.
05-07-2017 07:45 PM
05-07-2017 07:41 PM
05-07-2017 07:39 PM
Send a private message to a moderator and have them look into the problem. They would be able to rectify the situation for you. If you have never contacted a moderator before, this link may be useful.
